Cruiser
Author Topic: General grabber 315 / 75/ 16 lt  (Read 3545 times)
FJWally
« on: 19-Jun-13, 16:13 »
Hi All - put on a set of General Grabber red letters 315 / 75 / 16 LT last week in preparation for our Simpson Desert trip.
Motivations being.
wider profile to give improved stability and stay on top performance in sand
Heavier side wall construction to theoretically provide better puncture prevention
7 ply to provide improved puncture on the tread face
More agressive tread pattern to cover off any wet situations I experience in VIC high country later on.
35's to fill the wheel arches and better match the gear ratios I have fitted - finds and holds the plane better for cruising speeds.
Look good! :Cool:
Proven comp extreme offroad rally tire so they should handle anything I throw at them easily.
So far they are slightly noisier than the pro comp AT but not as noisy as the Mickey T 4 ribs.
Handling is great - grip is great on wet and dry bitumen.
measured noise in cab at 80kms on black top in traffic at between 69 to 73 dBA
Here are some pics
General grabber 315 / 75/ 16 lt * DSC_4182_zps3f68da20.
(141.17 kB, 1024x678)
General grabber 315 / 75/ 16 lt * DSC_4164_zps08
(110.06 kB, 678x1024)
General grabber 315 / 75/ 16 lt * DSC_4159_zpsec
(150.18 kB, 678x1024)
General grabber 315 / 75/ 16 lt * DSC_4152_zps18
(154.46 kB, 678x1024)
General grabber 315 / 75/ 16 lt * DSC_4139_zps0e85c86d.
(156.77 kB, 1024x678)
General grabber 315 / 75/ 16 lt * DSC_4122_zpsdd
(62.41 kB, 678x1024)
General grabber 315 / 75/ 16 lt * DSC_4120_zpsbbb6c86e.
(73.66 kB, 1024x678)
General grabber 315 / 75/ 16 lt * IMG_1167_zps86a4
(65.6 kB, 768x1024)
General grabber 315 / 75/ 16 lt * DSC_4119_zps9b5fbfd0.
(115.79 kB, 1024x678)
General grabber 315 / 75/ 16 lt * DSC_4134_zps2810f342.
(129.59 kB, 1024x678)
« Last Edit: 19-Jun-13, 16:16 by FJWally »
Hilux Max
« Reply #1 on: 19-Jun-13, 16:49 »
dont know how good they are going to be in the Vic High Country when wet considering they were designed for dry desert racing.
keep us updated with their performance. I think they are a good all terrain tyre but I wouldnt hold my breath for them to perform like a god muddy does.
Auto-Craft
« Reply #2 on: 19-Jun-13, 18:17 »
Max,
they will be better than the AT he had, without going to a full noisy mud tyre, I think is what he means, so more of an all rounder, that isn't as noisy as some of the other 4 rib style AT's out there, and should wear ok while being stronger in the tread and sidewall section.
GazLaz
« Reply #3 on: 19-Jun-13, 20:21 »
They look great!
FJWally
« Reply #4 on: 19-Jun-13, 21:37 »
As Darren says I'm not looking for a mud tyre - the few puddles I find will not trouble these one bit I would think - they do have a rep for being quite sticky on wet tracks though with the newer extreme traction technology compound they use - ie some rocky tracks as well as being a ball tearer on dirt and decent on black top which is a fair chunk of my driving.
Durability may be a concern but I never have run my tyres to the death rather to the point I feel they are effective so I dont expect 80k from them either.
So Nitto's they are not - I would think every bit as good as 4 ribs in wet and considerably better in dry.
Time will tell.
JD
« Reply #5 on: 19-Jun-13, 21:54 »
Look purdy!!
FJWally
« Reply #6 on: 20-Jun-13, 06:57 »
We have close to 6000k's to do in our Simpson trip (in less than 3 weeks :Awesome:) so will take some close ups and do a review when finished.
I'm hoping that prompts others to do the same - when they put on new gear - post up there reasons for - whatever they may be and let everyone know how they perform and if that was to their satisfaction as we all have different reasons and expectations.
General grabber 315 / 75/ 16 lt * DSC_4163_zpsbd
(110.39 kB, 678x1024)
elbo007
« Reply #7 on: 20-Jun-13, 08:28 »
Size looks great.  Looks chunky.
FJWally
« Reply #8 on: 02-Jul-13, 18:25 »
Had a couple issues fitting these as they are slightly larger than the MTR equivalent so the BMC needs to be done fairly precisely and alignment needs to also be done with great care- first guys that did electronic alignment had no clue but thankfully Darren's guys down in Geelong sorted it today - handles v-well now so I'm good to go for simmo.
One thing that has to go is the washer bottle - just touches but 8 can see that getting flogged on the rough desert roads so it has to be relocated which is a good thing really as it,s in a dumb spot anyway - the search begins for a decent size one!
Running pretty well for such a chunky tyre - great grip on blacktop tread looks like it's wearing evenly even with me throwing it around in corners to test everything is staying where it should.
More to come.
Alloy C/T
« Reply #9 on: 02-Jul-13, 18:44 »
Quote from: FJWally;11770
More to come.
What is the actual speed rating ?
Auto-Craft
« Reply #10 on: 02-Jul-13, 18:48 »
Mine has lasted 6 trips to the Desert, and has many a rub mark, only damage to it is where I hit it with the knife cutting the inner plastic when I first put 35's on, and had to plastic weld it with the soldering iron.
Alloy C/T
« Reply #11 on: 02-Jul-13, 18:57 »
Quote from: Auto-Craft;11780
What is the speed rating of the tyres ? Q ? or S ? or less ??
Auto-Craft
« Reply #12 on: 02-Jul-13, 19:12 »
Sidewall Style: Solid Red Letters
Serv. Desc: 121Q  [121 3197Lb ] [Q 99 mph 160 km/h ]
Load Range: D
Load Range   Ply Rating
D                      8
« Last Edit: 02-Jul-13, 19:19 by Auto-Craft »
mackie
« Reply #13 on: 09-May-14, 22:32 »
Where were the grabber srl purchased?
Cheers
crasha
« Reply #14 on: 09-May-14, 23:24 »
I really like the look of these tyres, do they come in a 285? How much are they per tyre?
SAW.
« Reply #15 on: 10-May-14, 00:12 »
Autocraft was importing them, not sure if they still are though. Not sure if they are abailable anywhere else.
FJWally
« Reply #16 on: 10-May-14, 08:19 »
The grabbers were great - smooth ride - heaps of grip - brilliant in same and gravel but they did start to chip up a little in high country which was why I sold them before i destroyed them
Now have MTR kevlars on which handle the rocky high country type roads much better.
Cruiser
